Octopus Box, LG G2 D802 IMEI repair, Unlock, yazılım güncelleme desteği ekledi
Octoplus/Octopus Box takımının LG Software v1.3.8 güncellemesine LG'nin yeni amiral gemisi olan G2 modeli için tam servis desteği ekledi. Güncellemenin detayları ise şöyle;
LG G2 AT&T D800 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D800P IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D801 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D801BK IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D801HW IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D801Z IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D802 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D802T IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D802TR IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D803 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D805 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D806 IMEI repair, Direct Unlock, Repair Security, Repair Wi-Fi MAC Address, Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
- D500 - added Write Firmware.
- D500BK - added Write Firmware.
- D500BKGO1 - added Write Firmware.
- MS500 - added Write Firmware.
[*]All supported operations are described in details in Software manuals ("Cable & Manual" button in the software).
Note: to perform Direct Unlock/Repair IMEI/Repair Security/Write Security Backup/Write NVM/Repair NVM operations for mentioned above D80x phones it is necessary to Root the phone first.
Autoroot operation is included in the Software for all tested firmwares.
If the phone will not be rooted by the Software automatically, you need to Root the device manually.
