Octopus Suite v1.0.3 Çıktı; Sony Ericsson Telefonlarına Sınırsız Unlock, IMEI, onarım
Octopus Suite v1.0.3 Çıktı, bu yazılım ile bomba bir haber geldi. Artık Sony Ericsson telefonlarına ücretsiz Unlock, Yazılım Yazdırma, IMEI değiştirme ve TA alanı onarma desteği eklendi. Octopus Box, 40 kredi karşılığında bu hizmeti veriyor. Bir sefere mahsus 40 kredi yüklemesinden sonra aşağıdaki işlemleri sınırsız olarak gerçekleştirebilirsiniz.
İndirme Linkleri:
[HIDE]Download Octopus Suite v1.0.3[/HIDE]
Octopus Suite v1.0.3 Yayınlama Notu:
  • Eklenen yeni telefonlar ve işlevleri:
    • LT15a, LT15at, LT15i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • E15a, E15i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • MT15a, MT15i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • ST18a, ST18i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • MK16a, MK16i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • ST17a, ST17i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • SK17a, SK17i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • X10a, X10i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • ST15a, ST15i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • MT11a, MT11i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • SO-01B - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • SO-01C - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • SO-02C - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • SO-03C - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • U20a, U20i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • E10a, E10i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • E16a, E16i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • WT19a, WT19i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • LT18a, LT18i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
    • R800, R800a, R800at, R800i, R800x, Z1i - UNLIMITED Unlock, Repair IMEI, Write Firmware, Read/Write/Repair TA.
  • Released some improvements to the main software.
To benefit from Octopus Activation for Sony Ericsson press "Activate SE Unlimited" button in "Support & Options" tab and follow instructions.
#2
Cevap: Octopus Suite v1.0.3 Çıktı; Sony Ericsson Telefonlarına Sınırsız Unlock, IMEI,
Bu yazılım için box gerekiyormu acaba? Birde 40 kredi 14 dolar görünüyor.Acaba başka birşey satın almak gerekiyormu?
40 Kredi'lik bir aktivasyon ve Octopus Akıllı kart veya Octopus Box gereklidir. Kredi ile aktivasyon bir sefere mahsustur.
A
alper4747
Guest
#4
yanlış bilgi veriyorsunuz burda yazdığınız bir sürü modele müdahale edilmiyor
LT18İ---LT15İ---ST18İ Bunlar yapılmıyor....
#5
s.a alper ustanın dediği gibi ama 12W14 ve üstü için geçerli alt versionlardan LT15İ Yaptım fakat (12W16, 12W18, 12w25 and 12w26.12w23..) gibi versionların hiçbirini yapmıyor lt18i st18i lt15i gibi modellerde
Please look time of producing of your phone (look at label under the battery). If your phone was produced later than 12W14 (12W16, 12W18, 12w25 and 12w26.12w23..) - such new phones are not supported by no one tool
Telefonunuzun üretme süresi (pilin altında etikete bakın) bakınız. Telefonunuzu daha sonra 12W14 (12W16, 12W18, 12w25 and 12w26.12w23..)daha üretildi varsa - örneğin yeni telefonlar hiç kimse aracı tarafından desteklenmiyor
Moderatör tarafında düzenlendi:
#6
Platform: SE Qualcomm
Selected model: LT18i
Please, reconnect battery, attach testpoint and connect USB cable...OK
Sending preloader...OK
Please, disconnect testpoint.
Waiting for preloader...OK
Reading info...
IMEI: 352600-05-898582-2
MSN: BX902YAVYG
Sending loader...OK
Reading info...OK
Checking security...OK
Reading security area...OK
Backup saved to "C:\Program Files\GsmServer\Octopus_Suite\BACKUP\Sony
Ericsson_LT18i_35260005898582_08-09-2012_13-07-24.BKP"
Checking TA...OK
Old IMEI: 352600-05-898582-2
New IMEI: 351808-01-379262-8
Calculating security on the server...
Sending TA to server...OK
Calculating. Please, wait...OK
Receiving TA...OK
Checking security area...OK
Writing security area...Failed!
Error code: ALP2OASDHH verdiği hatada bu............................................!
