SL-BOX Samsung v1.40 Samsung, Direct Unlock, Repair Imei, Write Firmware)
SL-BOX yazılımı Samsung v1.40 güncellemesi ile bir çok Samsung modeli için Read Codes, Direct Unlock, Repair Imei-Write Firmware servis desteği ekledi. Samsung'un en son çıkan akıllı telefonlarına ve Tabletlerine tam servis desteği sunan yazılım güncelleme detayı aşağıdaki gibidir.
BY FLASH MODE (USB and SLBoX)
C3011 - Read Codes, Write Firmware, Patch MSL
C3200 - Read Codes, Write Firmware, Patch MSL
C3200g - Write Firmware, Patch MSL
C3530 - Write Firmware, Patch MSL
E2152i - Write Firmware, Patch MSL
E2230 - Write Firmware, Patch MSL
E2232 - Read Codes, Write Firmware, Patch MSL
E2330 - Read Codes, Write Firmware, Patch MSL
E2530 - Read Codes, Write Firmware, Patch MSL
E2652 - Write Firmware, Patch MSL
E2652w - Write Firmware, Patch MSL
S3310i - Write Firmware, Patch MSL
S3350 - Write Firmware, Patch MSL
S3353 - Write Firmware, Patch MSL
S3550 - Write Firmware, Patch MSL
C3310 - Write Firmware
C3312 - Write Firmware
C3330 - Write Firmware
C3332 - Write Firmware
C3350 - Write Firmware
C3560 - Write Firmware
C3750 - Write Firmware
C3752 - Write Firmware
E2600 - Write Firmware
BY TEST MODE (by USB and by SLBOX, some models/fw work by usb and some by uart)
C3011 - Read Codes, Unlock, Repair Imei - after Patch MSL
C3200 - Read Codes, Unlock, Repair Imei - after Patch MSL
C3200g - Read Codes, Unlock, Repair Imei - after Patch MSL
C3530 - Read Codes, Unlock, Repair Imei - after Patch MSL (some fw can work without Patch MSL)
E2152i -Read Codes, Unlock, Repair Imei - after Patch MSL
E2230 - Read Codes, Unlock, Repair Imei - after Patch MSL
E2232 - Read Codes, Unlock, Repair Imei - after Patch MSL
E2330 - Read Codes, Unlock, Repair Imei - after Patch MSL
E2530 - Read Codes, Unlock, Repair Imei - after Patch MSL (some fw can work without Patch MSL)
E2652 - Read Codes, Unlock, Repair Imei - after Patch MSL
E2652w - Read Codes, Unlock, Repair Imei - after Patch MSL
S3310i - Read Codes, Unlock, Repair Imei - after Patch MSL
S3350 - Read Codes, Unlock, Repair Imei - after Patch MSL (some fw can work without Patch MSL)
S3353 - Read Codes, Unlock, Repair Imei - after Patch MSL
S3550 - Read Codes, Unlock, Repair Imei - after Patch MSL
ANDROID: Read Codes (lower Android 2.3), Direct Unlock (Android bellow 3.0), Repair Imei (all until android 2.3.6, if higher downgrade it)
SAMSUNG A927 - Read Code - Direct Unlock - Repair Imei
SAMSUNG Flight 2 (AT&T) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxt Tab (KOR) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Captivate (AT&T) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Captivate (Rogers) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Giorgio - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S (CN) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S 4G - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S Fascinate 3G+ - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S FEMME (KOR) - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S GA - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S Glide - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy S2 - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy SL - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab - (AT&T) Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab - (Rogers) Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab - (TMOB) Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab 7.0 - Read Code - Direct Unlock - Repair Imei
SAMSUNG Galaxy Tab SC-01C - Read Code - Direct Unlock - Repair Imei
SAMSUNG Gidim - Read Code - Direct Unlock - Repair Imei
SAMSUNG I896 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I897 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9000 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9000B - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9000L - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9000M - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9000T - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9003 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9008 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9010 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9020 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9020A - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9020T - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9032 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9088 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9100 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9100L - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9100P - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9100T - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9103 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9103B - Read Code - Direct Unlock - Repair Imei
SAMSUNG I9103L - Read Code - Direct Unlock - Repair Imei
SAMSUNG I927 - Read Code - Direct Unlock - Repair Imei
SAMSUNG I927 Galaxy S II - Read Code - Direct Unlock - Repair Imei
SAMSUNG I927R - Read Code - Direct Unlock - Repair Imei
SAMSUNG I987 - Read Code - Direct Unlock - Repair Imei
SAMSUNG N023 - Read Code - Direct Unlock - Repair Imei
SAMSUNG N033 - Read Code - Direct Unlock - Repair Imei
SAMSUNG N7000 - Read Code - Direct Unlock - Repair Imei
SAMSUNG N7500 - Read Code - Direct Unlock - Repair Imei
SAMSUNG Nexus R - Read Code - Direct Unlock - Repair Imei
SAMSUNG Nexus S - Read Code - Direct Unlock - Repair Imei
SAMSUNG Nexus S - (AT&T) Read Code - Direct Unlock - Repair Imei
SAMSUNG Nexus S - (TMOB) Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000 - Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000L - Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000M - Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000N - Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000R - Read Code - Direct Unlock - Repair Imei
SAMSUNG P1000T - Read Code - Direct Unlock - Repair Imei
SAMSUNG SHW-M180S - Read Code - Direct Unlock - Repair Imei
SAMSUNG SPHONE (CN) - Read Code - Direct Unlock - Repair Imei
SAMSUNG T849 - Read Code - Direct Unlock - Repair Imei
SAMSUNG T959 - Read Code - Direct Unlock - Repair Imei
SAMSUNG T959D - Read Code - Direct Unlock - Repair Imei
SAMSUNG T959P - Read Code - Direct Unlock - Repair Imei
SAMSUNG T959V - Read Code - Direct Unlock - Repair Imei
